99 disco with ace /now w/o ace
Old Apr 25, 2011 | 04:11 PM
thehrdway's Avatar
Default 99 disco with ace /now w/o ace
so I bought a parts car and the person before disconnected the ace by changing the belt .Leaving out the cornering pulley , would this affect the power steering ? ... i bought it as a parts car but am thinking of salvaging her , and is oil in the air intake normal.
Old Apr 25, 2011 | 08:00 PM
No that will not affect the power steering but it will not handle correctly.
No there is not supposed to be oil in the intake.
How well does it run?
Old Apr 25, 2011 | 08:15 PM
thehrdway's Avatar
it ran good it has a leak around the timing chain is what he said but the air filter is clean..the reason i ask is I could probably us the pas pump but no more fluid in the resivoir
Old Apr 26, 2011 | 06:43 AM
drowssap's Avatar
if the ACE has been disconnected then I would "assume" that you would be pretty much running the truck without the ad of swaybars, I would think.
Old Apr 26, 2011 | 09:10 AM
Why would you disconnect the ACE, it is one of the better features on your Disco.
Old Apr 26, 2011 | 01:20 PM
thehrdway's Avatar
i bought the truck that way he ran the resivoir dry I am fix my 99 disco II with it ..iy supposedly started rocking back and forth when he was driving it....
Old Apr 26, 2011 | 01:41 PM
thehrdway's Avatar
Default rotors?
does that little center nut have to come out or not ,i ve found conflicting awnsers my rotor doesnt want to come off? and the rave says it does but I cant remove it ...
steveo2000
Oct 30, 2024 08:31 AM
Tin_Man
Apr 12, 2014 11:12 AM
bballjames
Sep 1, 2012 10:01 PM
tbuckt007
Apr 13, 2010 11:46 AM
alrd
Nov 17, 2006 11:25 AM
