99 Disco I getting stuck in park
Old Dec 29, 2008 | 04:09 PM
larry99discoI's Avatar
4wd High
Default 99 Disco I getting stuck in park
I've been searching the posts for info on this and all I can find relate to the Disco II.
Seems I have a bad Brake Light Switch. Brake lights are not working, as well as shifter stuck in park.
Is the fix the same for Disco I as the posts for Disco II?
When I search the part # at Atl. & Brit., I come up with LR005794G (replaces AMR2010G) at $64.95 us.
Other posts for the Disco II show the part at $18.95.
Can anyone help? Is this the correct part#?
Any detailed explanation of changing the switch would be greatly appreciated (very novice mechanic).
Thanks
Old Dec 29, 2008 | 04:17 PM
Default RE: 99 Disco I getting stuck in park
The same fix!!
Old Dec 29, 2008 | 05:55 PM
If AB says that is the part then that is the part.
Also check your local autoparts store.
amer_qureshi
Jul 10, 2024 02:03 PM
Roywilliams14
May 17, 2014 01:27 PM
ImQuattro
May 1, 2014 08:36 PM
Scope
May 2, 2013 03:54 PM
larry99discoI
Dec 29, 2008 04:15 PM
