99 Disco I will not crank
Old Jun 8, 2007 | 06:25 PM
lrd99's Avatar
8th Gear
Default 99 Disco I will not crank
Hi Everyone!
Please help! My baby is stuck at work in the parking lot. The key will turn in the ignition, lights come on in the cabin, and the dash board, but it will not crank. Please tell me this is a quick and cheap fix!
Old Jun 8, 2007 | 06:28 PM
98roverguy's Avatar
Default RE: 99 Disco I will not crank
Turn the headlights on, have someone stand in front of the vehicle, if the lights dim to almosty nothin then probably a dead battery, which would need further diagnosing for potential alternator or connection problem. If the lights look good then probably a starter or bad connection. Check you battery terminals and connection. Most no starts are connection problem related. Try jumping it too. Buy a voltmeter and check out the voltage of the battery and while you crank it.
Old Jun 8, 2007 | 06:53 PM
If after following the last recommendations, if it doesn't start get back to us this weekend.
Mike
Old Jun 8, 2007 | 10:01 PM
lrd99's Avatar
8th Gear
I really appreciate the fast reply. Idisconnected the battery and took infor a voltage read. A bad cell was found but it had a voltage reading of 12 volts. I just went ahead and got a brand new battery. After installing it shestill will turn. I made sure she was in park and everything. I do here clicks and from I have read from other postsit may be the starter.She did notgive any warnings or anything,she was firing up strong one minute and the next nothing. I'm lost. The clicks seem to come fromthe center console on the passenger side.Everything lights up on the dashbut shejust will not turn. If you have any insight ut would be greatly appreciated.
Old Jun 9, 2007 | 07:07 AM
Lets talk and walk you thru this.
Mike
303-862-7680
Colorado
Old Jun 10, 2007 | 01:02 AM
DiscoPhil's Avatar
8th Gear
Alarm immobilizer...? Try arming and disarming you alarm. Good luck!
Old Jun 10, 2007 | 11:43 PM
N.Franklin's Avatar
Try bypassing the starter solenoid? Id check to make sure its not gone bad before going to the starter itself.
Old Jun 11, 2007 | 03:05 PM
robdis96's Avatar
Key components of a good start are fueland ignition. Make sure you have those then branch out from there. I am sure Mike will get ya going from reading previous post, just givin info.
Old Jun 29, 2007 | 06:38 PM
N.Franklin's Avatar
So, what came of this? I just had the same problem with my 99' Disco 1, I havent even seen the vehicle yet other than pictures from the wife and already spend $400 on replacement parts, hope I dont have to buy a starter now too.
Gmacfilm
Dec 4, 2014 02:38 PM
tripledbucks
Dec 2, 2009 07:07 PM
cellman01
May 4, 2009 11:57 AM
Disco SoccerMom
Jan 15, 2009 11:35 AM
culligan
Feb 25, 2006 07:50 PM
