Key will not come out, truck will not crank
Old Jan 10, 2009 | 04:04 PM
Disco SoccerMom's Avatar
Default Key will not come out, truck will not crank
I just drove up in the garage, everything was fine. I turned the truck off, but the key will not go back enough to come out. So I tried to crank it again, it would not do anything. Battery is not dead, everything inside works, radio, wipers, lights, etc.
Please help!!
Old Jan 10, 2009 | 04:09 PM
NiteTrain's Avatar
Default RE: Key will not come out, truck will not crank
are you certain the transmission is in park?
Old Jan 10, 2009 | 04:10 PM
Yes I searched "stuck key" and that is the first thing I checked..
Old Jan 10, 2009 | 04:20 PM
NiteTrain's Avatar
can you move the gear shifter? if so try moving it through the gear range a few times and then into park.
Old Jan 10, 2009 | 04:22 PM
mwindth's Avatar
There are people more knowledgeable than I, but maybe the ignition switch is bad?
Old Jan 10, 2009 | 04:24 PM
NiteTrain's Avatar
I am guessing this is a DII discovery?
Old Jan 10, 2009 | 05:28 PM
ORIGINAL: NiteTrain
Yes, sorry.
Old Jan 10, 2009 | 05:37 PM
If the switch is bad and it won't crank, am I going to have to get it towed or is there something I can do?
Old Jan 10, 2009 | 06:09 PM
NiteTrain's Avatar
ORIGINAL: Disco SoccerMom
most vehicles you can jump the ignition switch and drive it as long as the key is in the correct position and the steering wheel is not locked, but I am not certain if you can do this with a rover. Somebody on here should know the answer.
Old Jan 10, 2009 | 06:18 PM
Put your foot on the brake, turn the key to "run" and then shift to neutral, and then try and start the truck.
If it starts then you were not all the way in park.
Are you parked on a hill?
If so set the parking brake before trying to shift into park.
Let us know how you make out.
