99 Disco II 120k mi
99 Disco II 120k mi
hello all,
First of all my check engine light is on. P0446 Evap vent circuit. then im leaking oil, it deff seem to be towards the front of the engine. i already had valve cover gaskets done. every single one of my door locks wont open with the remote key, i hear a sound like its trying, so i have to manually insert the key like in the old days. it will lock with the key lock button, but not open. I want to know how to remove my radiator. And finally i want to know if i can purchase only the fiber glass thing that covers my spedometer and rpm meter, cause i kind of cracked it.
ps does anyone have the info on headlight conversion?
thank you for your time.
RE: 99 Disco II 120k mi
GET RID OF YOUR K&N AIR FILTER!!! IT WILL KILL YOUR MAF SENSOR!!!!
You need a new door lock actuator, replace the drivers door lockand then see if the rest work after that, the drivers door controls all the rest.
For your dash and door lock go to,www.roverlandparts.com
Why do you want to remove your radiator?
Take your trk to the DIY carwash and degrease the engine, then start looking for leaks.
ORIGINAL: Spike555
MARSRover
06-22-2012 01:47 PM
tsuami1
02-05-2008 09:04 PM
