99 Disco II 120k mi
Old Jun 24, 2008 | 04:27 PM
arsenalgunners's Avatar
3rd Gear
Default 99 Disco II 120k mi
hello all,
First of all my check engine light is on. P0446 Evap vent circuit. then im leaking oil, it deff seem to be towards the front of the engine. i already had valve cover gaskets done. every single one of my door locks wont open with the remote key, i hear a sound like its trying, so i have to manually insert the key like in the old days. it will lock with the key lock button, but not open. I want to know how to remove my radiator. And finally i want to know if i can purchase only the fiber glass thing that covers my spedometer and rpm meter, cause i kind of cracked it.
ps does anyone have the info on headlight conversion?
thank you for your time.
Old Jun 24, 2008 | 04:44 PM
Default RE: 99 Disco II 120k mi
GET RID OF YOUR K&N AIR FILTER!!! IT WILL KILL YOUR MAF SENSOR!!!!
You need a new door lock actuator, replace the drivers door lockand then see if the rest work after that, the drivers door controls all the rest.
For your dash and door lock go to,www.roverlandparts.com
Why do you want to remove your radiator?
Take your trk to the DIY carwash and degrease the engine, then start looking for leaks.
Old Jun 24, 2008 | 07:14 PM
Disco2Guy's Avatar
Headlight Conversion. A lot of work btw.
Old Jun 25, 2008 | 07:30 PM
3rd Gear
ORIGINAL: Spike555
Well its leaking, butnot that bad yet, i have the replacement. i tried, but failed. i dont know how to get to the screwstoward the bottom. or how to remove theblack plastic thing that surrounds the fan. thanks for ur responses.
Old Jun 25, 2008 | 09:15 PM
I am not sure how to remove the fan shroud, it should just unbolt and pull right out. Same with the radiator.
MARSRover
Jun 22, 2012 01:47 PM
moody
Jun 5, 2011 10:34 AM
umoms
May 23, 2010 09:04 AM
BajaBound
Jan 29, 2009 10:14 AM
tsuami1
Feb 5, 2008 09:04 PM
