99 Disco II with 6 codes and three amigoes... please help where to start :)
Old Dec 10, 2012 | 08:57 AM
Twistid's Avatar
Haha that was my question above, if I could use RTV or glue ... Yes I think I will try to rub a little RTV (silicone sealant) and tape to try to seal it up.
Old Dec 10, 2012 | 09:01 AM
Twistid's Avatar
Also I think I will purchase just the two front O2 sensors for now. When I was searching the O2 sensor codes they all seemed to be front related.
P0152 02 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
Sensor 1 means front O2 sensor and Sensor 2 refers to rear sensor right? Bank 1 is driverside and Bank 2 is passenger?
Old Dec 10, 2012 | 09:19 AM
lr2001silver's Avatar
Banned
Correct-da-mondo
Old Dec 10, 2012 | 09:30 AM
Banned
Vac leak your talking about that hard plastic line runs behind the motor over to the driver side to the brake booster, you will find it towards the bottom of the booster and it has a big rubberish plug on that end. You could find the crack and cut the line there cut out a inch or two section and then go to hardware store and find a hose that's big enough to slip over original hard plastic line, go home and put some adhesive on the original line and slip new hose over both ends let seal and your good.
Old Dec 10, 2012 | 09:48 AM
Twistid's Avatar
It's to close to the red clip to cut it off and slip on a larger hose to seal it up. I think I'll have to use silicone sealant to try to seal it up, if not I'll probably have to replace the whole thing. Can I pull out that red clip that goes into the head ?
Old Dec 10, 2012 | 02:11 PM
jfall's Avatar
Put the codes into here
http://enginecodemaster.com
Broken08
Jul 31, 2015 03:49 PM
NWROVERS
Mar 10, 2015 03:17 PM
buick56
May 15, 2013 06:11 PM
04SSHD
Apr 11, 2012 06:20 PM
matt3502
Oct 25, 2011 10:41 PM
