99 Disco II AC Re charge?
I just recharged by '01 DII with one of the auto store units. It improved the cooling for a few days, then I discovered I had a leak. May want to check for leaks prior to recharging. The parts store should have a UV dye to put into the A/C system and then with a UV light, find any possible leaks. If you search there are several threads on how to recharge your system.
Same thing swiss said about checking for leaks first and foremost.
I just recharged mine (after checking for leaks) and its been great ever since. If you get one of the DIY kits, be sure it has a gauge on it so you can check the low pressure readings. It will tell you the numbers you need to be at on the back of the bottle. You will most likely need a 30-36 oz can if your A/c is running that bad. Mine was about the same and took the full 30 oz.
KBW
03-29-2009 07:34 AM
