Sponsored by: CARiD
Does your L.R. dealer charge for a code read?
Old Dec 19, 2008 | 08:15 AM
nola000's Avatar
Default Does your L.R. dealer charge for a code read?
Like the title says...does your local Land Rover dealer charge you when you bring your truck in to have the codes read/checked. Not an actual physical service, just a hookup to the computer.
I just bought my first Rover (2004 SE7 Disco) and I need to know what codes are causing the 3 Amigos to stop by unannounced every so often. I put my OBDII scanner on it and got P1415 and P0441. Its my understanding that you need a T4? or an AutoLogic? system to read some other set of codes that will tell you what is causing the Amigos visits. Are the OBD codes what I need to know? Or is this a dealer only code read? If it is, are they going to charge me for it and if so, how much?
Old Jan 17, 2009 | 03:51 PM
jorgef858's Avatar
Default RE: Does your L.R. dealer charge for a code read?
good question...id like to know the same. anyone?
Old Jan 17, 2009 | 04:58 PM
Camdisco24's Avatar
Depends on the dealer. If you have them read and cleared they may charge you a bit. Some with just run the codes and tell u what needs to be done, with no charge. If you need to have them read by LR, which some codes do, go into it expecting to pay a SMALL fee. I dont want to give you an exact number, because every place is different. Some may charge nothing.
RedRover928
Jan 31, 2013 09:26 AM
billyd1967
May 20, 2011 10:09 AM
bikingteacher
Sep 18, 2010 09:59 AM
mlnelson87
Jan 10, 2006 04:57 PM
