99 Disco II overheating
Old Jul 4, 2011 | 10:51 AM
bcameron70's Avatar
Unhappy 99 Disco II overheating
Hey there, I have a 99 Disco II,
My temp gauge started rising from nowhere, then leveling out about 3/4 way up. After a while more it would finally start rising again, and I would have to turn on the Defrost to HI to get the engine temp back down. I was at a constant RMP and load
I have changed the water pump and Thermostat
I have flushed the coolant system with water also
I have bled the system according to rave, water level stays good.
When I start the engine, I can wait about 10 minutes and I hear the viscous coupling kick in.
So...why am I still having cooling issues and they are not constant cooling performance? I am in maine, ambient has been no higher than 80 MAX, still happens when 60degrees out.
Has anyone seen where the Viscous Fan coupling kicks out when it's hot?
I bought this vehicle in November with 167K, I now have 175K on it, not sure when Viscous Fan was done last. It's a pretty expensive piece though...
Thoughts are appreciated, thank you!
Old Jul 4, 2011 | 01:01 PM
DarylJ's Avatar
So this is when sitting still?
If so, does it overheat while you're moving.... specifically highway driving? If it does, that will rule out the viscous coupling and fan.
Did you check your thermostat before installing to see if it opens properly? Have you check if your radiator hoses are both hot and check for cold spots in the radiator (an IR thermometer is good for this).
Old Jul 4, 2011 | 02:35 PM
Send me your number and quit driving it till we can talk so you don't cause any more damage.
Old Jul 5, 2011 | 09:11 AM
bcameron70's Avatar
I do have an IR thermometer.
Mike if you want to e-mail me your number I'll call. ben@harbordigitalsystems.com
The issues happened before the thermostat changeout, so with the new unit it is doing the same thing.
bcameron70's Avatar
...and yes...it still starts to creep up while driving on highways.
Old Jul 5, 2011 | 10:08 AM
DarylJ's Avatar
Ahh..OK. So that will tend to eliminate the fan/clutch, because at highway speeds the fan pretty much doesn't matter.
I'd check to see if you have a clogged radiator with your IR thermometer. Of course, the center should be a bit cooler since that's where the bulk of the airflow is sitting still, but if the top and bottom is significantly different or you can find areas that are significantly cooler, you can be pretty sure it's gunked up in there.
Old Jul 5, 2011 | 11:37 AM
bcameron70's Avatar
I just ordered a Radiator, I'll install it this weekend. I'll test drive and reply afterwards!
Thank you!
Old Jul 5, 2011 | 04:18 PM
janderso's Avatar
5th Gear
Disco 2002 just overheated this morning for the first time. Mechanic says it's a freeze plug. I think it's the thermo stat-looks dark brown.
Should I start with the thermostat?
Old Jul 5, 2011 | 04:48 PM
DarylJ's Avatar
Edit: new thread started, never mind.
Old Jul 5, 2011 | 06:11 PM
Bet your mechanic saw you coming, have you verified it's a freeze plug, do you know they hardly ever fail on a Rover, have you lost all you coolant, which a freeze plug will cause? If not find an honest mechanic or send me your number and I'll walk you thru what to do.
Tom Condon
Oct 19, 2006 08:22 PM
riebs
Aug 29, 2006 03:05 PM
procurbusa
Aug 14, 2006 03:19 PM
forbin10
Dec 1, 2005 07:55 PM
bakerww
May 24, 2005 09:35 PM
