99 Disco II -- PCV Valve Question
Old Jul 7, 2006 | 10:45 AM
rirover's Avatar
Default 99 Disco II -- PCV Valve Question
I picked up a PCV Filter Tune up kit because I noticed that I had some oil seeping from the passenger side valve cover near the rear. I was told this was a symptom of a clogged PCV filter. I have never changed this thing in the 47k I have put on so I figured I would give it a try. The kit consisted of a filter and two hoses. I have located the hose on the drivers side, but I dont know if there is a filter in there that I will need to change? The hose is in otherwise good condition and I figure if its not broke, dont fix it. Are there any filters under that I need to be aware of?
When I pulled the first one off, it was caked in a black tar type substance. How often should this item be changed? Does the Octane level I burn affect this?
Please advise.
CDT
Old Jul 7, 2006 | 05:10 PM
Default RE: 99 Disco II -- PCV Valve Question
I have 80,000 miles on mine and have never cleaned or repaced the hose, it has not rotted or gotten so and leaked. I will go check mine and get back to you, it is a good guestion.
How frequently do you change your oil, do you ever do an engine flush. If you change the oil every 3000 miles or so and do a flush once in awhile, it shouldn't get dirty.
Mike
Old Jul 7, 2006 | 06:02 PM
rirover's Avatar
Thanks Mike. I have never flushed the engine, but will be this weekend thanks to your advice. I change my oil very regularly at 3500. My hoses were fine, but that PCV filter device was CAKED.....
ORIGINAL: Disco Mike
Mike
Old Jul 9, 2006 | 02:03 AM
Bait's Avatar
ORIGINAL: rirover
Where did you get the kit?
Old Jul 9, 2006 | 02:23 AM
rirover's Avatar
Atlantic British -- SKU #9205B -- its like $35 for everything. Filter and two hoses. Next time I will just get the filter, my hoses seemed fine.
Old Jul 9, 2006 | 11:38 PM
Bait's Avatar
DII's with Bosch engine management don't tend to collapse the hoses. You can clean the filter/baffle. Engine oil flushes will not prevent this.
04BluDisco
Jun 2, 2024 12:12 PM
er1c
May 18, 2015 08:33 PM
Straight Shooter
Oct 26, 2011 10:03 AM
rravenn13
Jul 19, 2007 01:33 PM
