99 Disco II Seat heater too hot
Old Jan 24, 2010 | 06:54 AM
tbesselman's Avatar
Default 99 Disco II Seat heater too hot
I have a 99 Disco II and the drivers side seat heater gets too hot. The light on the button seems to work well. Is there a seperate thermostat somewhere, what should I look for and or replace.....thanks (passenger side works fine) andy ideas so I don't burn my butt anymore?
Old Jan 24, 2010 | 08:03 AM
sn1987's Avatar
funny but seat heaters are most common reasons for burned down cars (as i read), from what i know there is no thermostat at all, it is (should) just designed to produce only small amount of heat. Most of the time it fails is because some internal shortcut or that isolation (which acts as heat spreader) is broken.
I would let it check in service.
Mine gets hot but i like it, i switch it off when gets too hot though because since then i dont need it anymore (is warmed enough) and saves the energy
Old Jan 24, 2010 | 12:43 PM
Rovin4life's Avatar
if you think it gets too hot check both sides with a infared heat gun.
Old Jan 24, 2010 | 01:27 PM
tbesselman's Avatar
It definately gets too hot, it actually burns vs the passenger side temprature. I ride in it both as a passenger and as a driver, and as a driver, it gets so hot I have to turn it off......
Old Jan 26, 2010 | 04:53 PM
'BamaBoy's Avatar
My driver's seat gets super hot too. The seat is dis-colored in spots from the heating coils. I just turn the seat off when it gets too hot.
Old Jan 26, 2010 | 09:57 PM
NyTelTech's Avatar
I was getting the same thing, but in my case, just on the door side of the driver's seat. It actually felt like someone was pinching my @$$ on that particular spot. About a month later, it stopped heating entirely, and when I pulled the seat cover back found a scorch mark and small hole where it was burning me. Turns out the heating element shorted out, so now I have no driver's side heated seat. Possible this may be what is happening on your truck, so watch out. I think if I would have left it on, it would have ignited the seat, since none of the fuses blew.
Old Jan 27, 2010 | 07:26 PM
'BamaBoy's Avatar
Oh wow, maybe i should keep a closer eye on my seat then.
Old Jan 28, 2010 | 06:41 AM
tbesselman's Avatar
Are they easily replaced?
Old Jan 28, 2010 | 09:51 PM
NyTelTech's Avatar
Fuses, no. If you meant the heating element, I didn't get to replace it yet, but it doesn't seem that hard. Just remove the side cover by the door, then unhook the plastic tabs for the seat cover (they are on tight!). Once you get those off, there are several hooks to remove as well. That's as far as I got before work called and I had to wrap it back up in 10 minutes. Just haven't had the time to get the heating element, much less take it apart again..
Old Feb 4, 2010 | 11:38 AM
bdoyle1742's Avatar
Man I wish this happened to me, My 03 seats take a dick year to get "kinda" warm.
Pik
Mar 27, 2013 08:00 PM
94svt50
Jul 8, 2012 03:31 PM
LRScott
13
Apr 7, 2010 02:26 AM
Rover Chris
May 20, 2009 09:42 AM
