99 disco oil leak
Old Jan 7, 2009 | 02:00 PM
cnterline's Avatar
4wd High
Default 99 disco oil leak
seems like its leaking oil from rear of intake or rear of head gaskets,is this common on this year disco ,110k on motor
Old Jan 7, 2009 | 02:02 PM
Default RE: 99 disco oil leak
Sure, it will be either a valley pan gasket or the head gaskets. Are you sure you v/c gaskest bolts aren't just loose cause them to leak and go down the back of the engine?
How mechanical ar you?
Old Jan 7, 2009 | 04:09 PM
cnterline's Avatar
4wd High
I have my own shop,just not familiar with disco problems,gave it a quick eyeball and i cant fit a mirror behind the heads or intake from the top to see where the leak is coming from,doesnt appear to be the valve cover though
Old Jan 7, 2009 | 05:06 PM
Then start by pullin the intake, after all, it is an old Buick engine so you shouldn't get to stuck.
Shout when you have some information and I will tell you where to go the parts needed.
thearmlesswonder
Jul 27, 2015 10:16 AM
Phatrowles
Jan 9, 2014 10:36 AM
shonuff93
Mar 28, 2012 09:33 AM
tito5590805
Sep 27, 2010 11:32 AM
rgrizzard
Mar 6, 2008 10:16 AM
