99 Disco problem with removing key
Old Mar 7, 2008 | 02:50 PM
sparkdaddy's Avatar
Default 99 Disco problem with removing key
So here is the deal. Put the truck in park and turn the key off and the key doesn't come out. If you jiggle the gear shift the red light on the shift column comes on and then the key can be removed.
I'm assumming that I have a problem with the gear selector??? Can this be adjusted? Problems?
Thanks
Old Mar 18, 2008 | 10:44 PM
sparkdaddy's Avatar
Default RE: 99 Disco problem with removing key
Anyone?
Old Apr 17, 2008 | 03:17 PM
motormikeyman's Avatar
8th Gear
I'm not sure if your vehicle is same as 95 disco, but I had same problem... put it in park and the key would not come out. Turns out that the key also was not going into the "off" position all the way. I found that by removing the plastic column cover, you can see a small black plastic cover to the left and forward of the key cylinder. Pop off the little plastic cover and spray some lube on the metal pin sticking out, then work the shifter and key. This pin should drop down and lock the steering wheel (I think). Anyway, this worked for me.
Old Apr 17, 2008 | 04:19 PM
Yes there is an adjustment on the gear shifter, it isint engaging park all the way. You will most likely have to have a shop do it.
dirtlord
Jul 24, 2013 10:47 PM
dandyrover
Dec 29, 2011 05:01 PM
tallforever
Jun 18, 2008 03:21 AM
Chrisinhouston
Jan 10, 2008 07:58 AM
mrmozambique
Aug 23, 2006 03:34 PM
