'99 Discovery Code Issue
Old Jan 24, 2008 | 10:56 AM
knox99dis's Avatar
Default '99 Discovery Code Issue
hey guys! i have a '99 discovery kicking a code that says "trans range select sensor". i have reverse, nuetral and drive. no other gears. plus it seems that the transfer case is stuck and won't let me go into 4-wheel. this is a gen.2. any ideas???
Thanks!
c.h.
Old Jan 24, 2008 | 11:07 AM
Default RE: '99 Discovery Code Issue
Need the specific code number?
The switch in the tranny won't let you shift into low range cause it is not relasing the solenoid in the t/case.
By the way is this a D1 or 2?
Old Jan 24, 2008 | 12:22 PM
knox99dis's Avatar
MIKE,
THANKS FOR THE REPLY. THIS IS A D2. IT WAS ALSO UNDER WATER. I HAVE DRAINED THE TRANNY AND REPLACED THE FILTER AND FLUID. I KNOW I PROBABLY NEED TO DO IT AGAIN. WOULD THIS CAUSE IT TO KICK THE CODE? I'M WORKING ON GETTING THAT CODE NUMBER FOR YOU.
THANKS!
Old Jan 24, 2008 | 12:28 PM
You better talk to a tranny shop, draining the fluid won't help the tranny, you need to have it flushed to get all the water out and if you haven't damaged anything you may be OK.
bosshogt
Jan 20, 2014 09:29 PM
hatt53
Mar 27, 2013 05:16 PM
pixel
Mar 5, 2012 12:29 PM
sayeedA
Nov 15, 2011 11:02 PM
