99 discovery rim fit a 2003 discovery?
The bolt pattern is visibly different. The D2 uses a 5x120mm pattern common on newer European cars. The D1 uses a much less common, much larger 5x6.5inch pattern that I've never seen on anything other than Land Rovers.
Also, most D2 wheels are 8 inches wide, while almost all D1 wheels are 7 inches wide.
If the wheel bolts on without issues, and says land rover on it, you are good to go.
jaysan21
Mar 12, 2014 12:59 PM
jaysan21
Mar 11, 2014 06:51 PM
mddearing
Jul 21, 2008 09:08 PM
