99 discovery rim fit a 2003 discovery?
Old Oct 3, 2012 | 02:54 PM
PLOWER99's Avatar
Default 99 discovery rim fit a 2003 discovery?
Just wondering if a 99 16" rim will fit a 03 discovery with 18" rim? I have been looking just can't seem to find a straight answer on here.
Thanks
Old Oct 3, 2012 | 02:56 PM
jafir's Avatar
If it's a 99 discovery 2, yes. If it's a 99 discovery 1, no.
Old Oct 3, 2012 | 03:15 PM
PLOWER99's Avatar
How can I tell the difference between a 99 d1 rims and a 99 d2 rims? The person I am purchasing from no longer has vehicle just rims with tires mounted.
Thanks
Old Oct 3, 2012 | 03:31 PM
jafir's Avatar
The bolt pattern is visibly different. The D2 uses a 5x120mm pattern common on newer European cars. The D1 uses a much less common, much larger 5x6.5inch pattern that I've never seen on anything other than Land Rovers.
Also, most D2 wheels are 8 inches wide, while almost all D1 wheels are 7 inches wide.
If the wheel bolts on without issues, and says land rover on it, you are good to go.
Old Oct 3, 2012 | 03:37 PM
PLOWER99's Avatar
thanks!
Old Oct 3, 2012 | 05:02 PM
Actually so you don't get confused, there are some early D2 7" wheels out there also
' What size tire are you planning to use?
jaysan21
Mar 12, 2014 12:59 PM
jaysan21
Mar 11, 2014 06:51 PM
cavdiver2
Mar 28, 2013 09:33 AM
0304Disco
Aug 16, 2012 09:15 AM
mddearing
Jul 21, 2008 09:08 PM
