99 discovery transmission question...
Old Mar 17, 2009 | 03:50 PM
99LRD's Avatar
5th Gear
Default 99 discovery transmission question...
ok i just got this 99 LR discovery in on a trade, it has the 4.0 v8 and an auto
my question is the transmission only has park and reverse, no other gears are working....
my questions are: what model trans does this thing have?
is it the actual trans that im having trouble with
or something else like a shifter etc...
any information or tips will be appreciated, thanks
Old Mar 17, 2009 | 05:20 PM
AK Rover's Avatar
Is it a D1 or D2? Both were made in 99 and both had the 4.0 V8.
Old Mar 17, 2009 | 05:34 PM
You need to check the fluid level first, how you do that depends on if it has flush mounted door handles or ones that stick out.
Old Mar 17, 2009 | 07:38 PM
99LRD's Avatar
5th Gear
i havent got my hands on it yet so im not 100% sure, are the door handles the only way to tell between a d1 and d2?
whats the difference in a d1 and d2?
here is the picture i was given
Old Mar 17, 2009 | 08:17 PM
That is a DI.
DII's are wider and longer, have more electrics, LCD odometer, full automatic HVAC and a electronically controlled transmission and no dipstick to check the trans fluid level.
The DII ran from 1999.5-2004.
The DI from 1989-1999.
It has a dipstick to check the trans fluid level.
The ZF transmission is pretty much bullet proof, so if it is not low on fluid then the filter is clogged.
Once you get it home I would change the trans fluid and filter, drive it for a 1,000 miles and then change the fluid again.
Old Mar 17, 2009 | 10:15 PM
99LRD's Avatar
5th Gear
so you think its just a filter a fluid change fix? that would be great conisdering a trans rebuild is anywhere from $1000 to $1500
anybody else have any say?
thanks guys!
Old Mar 17, 2009 | 11:18 PM
AK Rover's Avatar
As much as I hate to agree with Spike, a filter and fluid change should do the trick. I would bet when you pull the dipstick if there is any fluid on it it will be black.
Old Mar 18, 2009 | 05:38 AM
Hey, whats wrong with agreeing with me? LOL
If you do need a new one dont get yours rebuilt, just buy a used one.
www.roverlandparts.com
www.autosportsunlimited.com
Old Mar 18, 2009 | 06:23 AM
99LRD's Avatar
5th Gear
thanks guys ill have to try it, i should get my hands on this thing next week when its delivered and i guess we will go from there
Old Mar 18, 2009 | 12:17 PM
handsome rob's Avatar
I agree the fluid and filter change should be the first ting to try. If you do need a tranny you can find a used one for around $600 bucks with a warranty, for a couple hundred more you can get a three year warranty with some low miles on it. Good luck and let us know how it works out.
