99 Landrover dico 2 v8 4.0 Help !
Old Mar 7, 2017 | 12:55 PM
Friday Night Disco's Avatar
Originally Posted by Mr.Poopy
Got a new one
before or after this happened?
do you have the ability to erase the code?
Old Mar 7, 2017 | 01:36 PM
Mr.Poopy's Avatar
Originally Posted by mollusc
Aside from all the misfire/emissions issues, it sounds like you have something serious going on with your transmission too. First thing to check is the fluid level, and also that your prop shafts are both still attached. Beyond that you're starting to get into more diagnostic territory so it could be anything from the torque converter to the flex plate to something internal to the transmission itself.
the fluids are ok and the prop shaft are still attached.Thanks for the info man
Old Mar 7, 2017 | 01:40 PM
Mr.Poopy's Avatar
Before i was getting it so i got a new gas cap. And to the second i do not.But will the code reader do it?
Old Mar 7, 2017 | 01:55 PM
LRD2rangel's Avatar
most OBII code reader have to ability to clear codes.
do that
try to start and scan for codes again
Old Mar 7, 2017 | 02:10 PM
Mr.Poopy's Avatar
do that
thank you will do.
Old Mar 7, 2017 | 03:44 PM
jamestfl's Avatar
thank you will do.
I'd venture a tentative guess that a new iacv, plugs and wires will clear most of those codes, maybe new coil packs too. But you dont know til you've tried. No idea on the tranny issues.
Old Mar 7, 2017 | 03:53 PM
mollusc's Avatar
Also a new purge valve. I was having repeated misfire and fuel trim issues until I did that.
After you do plugs, wires, and coils, other problematic parts may start to rise to the surface such as O2 sensors.
Old Mar 8, 2017 | 06:48 PM
Mr.Poopy's Avatar
Automatic Gearbox failure....
Old Mar 8, 2017 | 08:33 PM
Luckyjayb's Avatar
so the xyz switch?
Old Mar 9, 2017 | 06:44 AM
mollusc's Avatar
Grinding noises wouldn't seem to be switch-related.
