'99 Series I ABS Sensor Replacement...
http://roverparts.com/Parts/STC1749.cfm
This is what they look like, and the price has come down alot.
There will be one at each front wheel and one on the passenger? rear wheel. (there are ony 3 on a DI)
From the front of the truck they are pretty easy to find, look at the hub and you will see the only thing with a wire coming out of it.
If you do a search for "DI ABS" or the like you can find lots of info on DI ABS systems.
Second2None
12-06-2010 05:26 PM
