99 sub-woofer wiring q?
Old Oct 6, 2012 | 01:00 PM
parkerlander's Avatar
Default 99 sub-woofer wiring q?
Hi, has any one recently pulled out the subs? Going through this 99 I bought, fixing a myriad of problems, and did not hear any sound coming from the subs. I pulled it all apart and found all the wires cut to everything. There are only four wires coming from the harness, that feeds through the hatch, that I have found cut and taped. Is this correct? I do not see any power wires for this mini amp. I Hot-wired the subs into the front door lower speaker and one seems loud and one doesn't. Also one speaker is wired into the amp and the other is cut so not sure How it's all supposed to be configured and If I'm missing some wiring.
Any info would be appreciated!
see pics below!
Attached Thumbnails 99 sub-woofer wiring q?-rover-wiring.jpg   99 sub-woofer wiring q?-rover-wiring2.jpg
Old Oct 6, 2012 | 09:36 PM
pink & black stripe and red & black go to one speaker. Brown & black and white & black go to other speaker. See page from RAVE electrical circuits manual, has all the color codes, etc. Pix shows what connector would have looked like.
File Type: pdf
File Type: pdf
Old May 29, 2021 | 11:36 AM
Lcagee's Avatar
see pics below!
I have a question. Where is the amp for the subwoofer in the rear? Is the rear subwoofer assembly in the Phillips model the same as the subwoofer in the philips model?
parkerlander
Aug 13, 2013 04:36 PM
parkerlander
Aug 7, 2013 08:00 PM
JFerrari09
Audio/Visual Electronics
May 8, 2013 11:30 AM
guitarz32388
Jun 22, 2007 10:04 AM
puchungozback
May 1, 2007 09:05 PM
