Is this It?
Old Feb 9, 2014 | 11:36 AM
gribur's Avatar
Default Is this It? PICTURES
I know its been written up everywhere but wanted to verify this is all I need to do the front prop shaft
LAND ROVER DISCOVERY 2 FRONT PROPSHAFT REPAIR KIT - JGS 4x4 Land Rover Parts
I also wanted to see if anybody had found a kit like this in Canada? ty guys
Old Feb 9, 2014 | 12:24 PM
EVN137's Avatar
Don't know if there's one up north.
Don't reuse the old bolts/nuts.
Get new ones, and use self locking nuts.
Old Feb 9, 2014 | 01:02 PM
FlyingZebra34's Avatar
Yes that's one of them. You can replace the 4 nuts and bolts on the axle side but you can only replace the nuts on the T-case side as the flange is attached in such a way where you can't get the bolts out without removing it (30mm nut I think and like90 ft pounds) but it's not necessary. Just get new nuts that lock (nylock or something)
Old Feb 9, 2014 | 01:44 PM
gribur's Avatar
Default Pics added
I was able to get the camera under and snap some shots, I am crossing my fingers I am assuming right and it has been done. Take a look and please verify it for me, if it has been done my wife will be doing a happy dance as we wont need to spend any more yet lol. Here are the pics
Old Feb 9, 2014 | 02:37 PM
Janadi's Avatar
Your Wife will be doing the happy dance.
All looks good,just remember to grease them each time you do a oil change.
Old Feb 9, 2014 | 05:08 PM
ZGPhoto's Avatar
Looks like it has been done. Drop it and see if the centering ball is greasable, that's the part that matters.
Old Feb 9, 2014 | 05:22 PM
gribur's Avatar
Default question
Ok I see the grease nipples on it, but what about the centering ball, will there be a nipple from it ? do you need to remove the prop shaft to grease the centering ball? ty
Old Feb 9, 2014 | 05:37 PM
ZGPhoto's Avatar
Read allll the comments
Drop the shaft.
Old Feb 9, 2014 | 05:54 PM
gribur's Avatar
I read that, that's why I asked. If you need to oil the shaft every oil change, which is easy to get to, it just seems unlikely that all disco 2 owners drop the shaft every 5000 to oil the ball. Oh and the smiley was not intended to mean anything, my daughter asked me to ad it.
Old Feb 9, 2014 | 06:48 PM
ZGPhoto's Avatar
They don't, that's why they end up needing to replace the transmission after it breaks and busts a hole in the transmission.
I just do smiley faces on most of my comments
