Abrupt end to road trip in Disco
Old Dec 17, 2006 | 03:07 PM
soxfan's Avatar
5th Gear
Default Abrupt end to road trip in Disco
Hey
I'm having some disco issues. Im leaning toward a blown head gasket, but I wanted to know what you guys thought.
I started smelling something like smoke while i was driving, so I pulled over and opened up the hood. There was some smoke coming from the passenger side of the engine, down by the exhaust manifold. Didnt notice anything coming from the tail pipe. There was a small puddle of oil on the ground. Also missing a bit of coolant.
The next day, I kept checking my fluid levels. The oil dipstick was reading steady through the day, but I kept losing some coolant. Later, the oil warning light came on, so I shut the truck down and opened the hood to see what was going on.
The oil in the crank case was diluted with a ton of coolant and the smoke was getting much heavier.
I obviously had the truck towed home at that point.
Thoughts?
Old Dec 17, 2006 | 03:31 PM
Default RE: Abrupt end to road trip in Disco
You have lost your head gasket for sure, don't run the engine any more cause you are washing your bearings in coolant which can kill them also.
Make sur whoever works on your truck is familiar with your engine, inspect the heads and check and make sure your haven't dropped a cylinder sleeve.
Mike
Old Dec 18, 2006 | 06:13 PM
98roverguy's Avatar
Hope you havn't melted your cats too. fyi just did a head job on mine (98 DI GEMS). Don't know what year you have but hit me up if you need some help with that engine make. good luck!
Richard.rover
Jun 5, 2020 01:44 PM
dr. mordo
Jul 2, 2013 09:00 AM
pilsner
Jan 25, 2009 08:14 PM
unstable
May 20, 2008 07:45 PM
Bluejayranger
Jul 7, 2007 07:23 AM
