ABS 023: Gear Info Not Valid
I got this ABS code today, and am thinking a new neutral safety switch needs to be ordered. The switch I rebuilt was corroded. I will inspect the wiring as well. There is not much info in the rave.
What I am wondering if anyone has had this issue cause stalling or failure. I am not getting any other codes, but do not want to get stuck out and about.
Could it be adjustment? And how do you know if it is adjusted incorrectly?
Couldn't find this on a forum.
At Connector Pin C0662 the W, X, Y contacts from the Gear Position Switch go in to the BCU. I am guessing the corrosion is sending a confusing or intermittent signal in. The Dash know what gear it is in, but I wonder how much that has to do with the switch on the transmission or if that is determined by the gear shift. I am going to try an get under and inspect the switch.
https://www.rswsolutions.com/index.p...y-ii-abs-codes
I couldn’t find it! Anyway, when i rebuilt the xyz switch the front switch, w I suppose in the w,x,y,z, was really rusty. The signal is a combination of voltages from the combination of the four switches. This goes into the BCU at the pin connector referenced by the code.
