ABS 3 Amigos question
Old Dec 2, 2010 | 04:24 PM
tbesselman's Avatar
Default ABS 3 Amigos question
ok...this one is new for me....I have a 99 disco II with 102K, and the 3 amigos came on while braking, and I cycled the car and they went away.....then I pulled out my trusty abs reader, and got -
1.--Current Faults---->
Active Faults:
None
Logged Faults:
114:Shuttle Valve Electric Failure
<-END Faults
..--Previous Faults--->
Active Faults:
None
Logged Faults:
None
<-END Faults
Does that mean my shuttle valve is getting ready to die....I saw that Roverparts has a Shuttle Valve repair kit.........I want to get ahead of this one
Old Dec 2, 2010 | 05:04 PM
dcarr1971's Avatar
Search is your friend...this topic has been beaten to death...
Read through the repairs here: http://www.landroverclubvi.com/abs-mod.html
Old Dec 2, 2010 | 05:46 PM
GARovee's Avatar
Yeah search for SVS fault fix
Old Dec 2, 2010 | 07:52 PM
tbesselman's Avatar
will this do the sam thing???
http://www.roverparts.com/Parts/SWO500030.cfm
Old Dec 2, 2010 | 08:05 PM
GARovee's Avatar
No. The best SVS fault fix is to do actual wiring bypassing. You can find the instructions online. "option b" I believe it is. Try searching SVS fault fix option b. Should be how to bypass the SVS connectors.
Old Dec 3, 2010 | 08:54 AM
Go read Josh's Sticky thread at the top of the D2 section. At your mileage I would suggest you do the ground fix as well as the shuttle valve replacement using the complete kit from Falcom Works.
Old Dec 6, 2010 | 03:22 PM
tbesselman's Avatar
Mike - can I do the ground process from Josh and use this replacement from AB
it's have the price of the one from the other one.....just want to make sure they are the same
Old Dec 6, 2010 | 04:50 PM
As Josh has mentioned, go to Falcon works where you get an up-grades shuttle valve plus the seals and o-rings that fail causing the shuttle valves problems.
I will be doing mine in early January.
Old Dec 6, 2010 | 07:54 PM
GARovee's Avatar
I advise people to not only replace the SVS but to also do the wiring bypass! There was nothing wrong with my switches that the kit replaces. The problem was with the circuit plug that Josh highlights. In my opinion the MAIN issue with these is the connection from the SVS and not the SVS them selves. If you're going to replace the SVS you might as well take 5 minutes and bypass the SVS circuit connector. Just read through
Joshs page.
Old Dec 7, 2010 | 05:19 AM
tbesselman's Avatar
ok.....makes sense......the only thing i;m worried about is bleeding the brakes is it hard to do......I don't wnat to do the mod and get stuck at home without any brakes, if I have to take it somewhere to bleed them.....any reccomendations on the brake fluid part?
