ABS 3 Amigos question
Old Dec 7, 2010 | 05:45 AM
hilltoppersx's Avatar
if you don't know how to bleed the brakes either A: learn how its not that hard or B: use the repair option without disconnecting the brake lines (which i did) its not that hard to just wedge the unit up and get under it with a key.
Old Dec 7, 2010 | 04:58 PM
GARovee's Avatar
Ditto. I did it with out disconnecting the lines. Just prop it up and work under it.
Old Dec 8, 2010 | 07:34 PM
tbesselman's Avatar
actually just bought a one-man bleed kit, figured I maight as well flush the system while I was at it......I just got a little nervous because I hadn't done it before for a car.......I've doen motocross clutch, brake etc...........I have my new Falconstor SVC on the way along with the rest of the parts....I'll post the results......
Old Dec 8, 2010 | 07:49 PM
GARovee's Avatar
Keep in mind that even if you bleed the lines you still have to bleed the ABS modulator. The dealer does it by using testbook to run the pump. You the home mechanic will have to do it by finding a steep drive way or hill and use your HDC. It'll run the pump long enough to get all the air out. Then rebleed the lines. You'll have to bleed the lines first so that you have brakes to begin with, then use HDC a few times to bleed the abs pump, then bleed the lines again.
Old Dec 13, 2010 | 12:36 PM
tbesselman's Avatar
Default ABS Shuttle Valve replacement question
Originally Posted by Disco Mike
As Josh has mentioned, go to Falcon works where you get an up-grades shuttle valve plus the seals and o-rings that fail causing the shuttle valves problems.
I will be doing mine in early January.
Mike - the Falcon works kit came in, and I made Josh's mod to the Shuttle valve (the ground and wire connections - the kit als includes 4 little valve plunger snap rings and two shuttle valve plunger seals - do I need to install them in the modulator too, or can I skip that - I was hoping to use Josh's option B and just replace the shuttle valve with the re-wiring.
cammyr01
Jan 5, 2015 02:42 AM
iplayblues4u@comcast.net
Jan 6, 2010 08:43 AM
dammad
Jan 26, 2009 01:50 PM
umoms
Jan 3, 2008 08:40 AM
offroader
Jun 16, 2007 12:31 AM
