ABS Amigo
I have an 2003 Disco II. I have the 3 amigos showing up right now. I went to the dealer to have the codes read, and they indicated that I needed a front hub assembly. They did not give me codes (although I should have demanded them). I am located in Central Jersey. Does anyone around where I am, have the ABS Amigo that I could borrow. I will come to you and I don't mind paying some for the use if it. I would just like to get to the bottom of the issue.
thanks
thanks
Yes that is true. You will not have ABS or traction control until you fix the sensor and clear the ABS codes with an ABS amigo or really any good scanner that can do ABS codes. Maybe try to find an indy shop with an ABS scanner.
