ABS amigo reader
You can also look in to the Autel AL 619 scanner. You can get it on Amazon for around 200 bucks and it is a full functioning scanner that reads OBDII and ABS/SRS codes from pretty much any vehicle Land Rover included. I bought one when I had the three Amigo lights on. I was considering the ABS Amigo but I am glad I went with the Autel scanner.
The only current ABS code was for a bad PWM signal from the ECM.
021:Engine PWM Signal Bad
When we cleared the ABS code it didn't seem to return immediately, so I think that is a good sign.
You also had an ECM code of P1592 and also a couple of misfires codes and catalyst codes.
I figured I'd post the codes here in case someone has any ideas. My first thought, with those two codes together, is that the two computers are sometimes having trouble talking to each other.
You might want to get a replacement gauge cluster, so that you can more easily see if the amigos are on. You might check with Nigel's Car Place, I think he has used parts, or see if there are any u-pull-it type salvage yards nearby that might have one for cheap. There is a yeard near me that shows to have one for $10 at Car-Part.com--Used Auto Parts Market
DiscoBenjamin
10-14-2011 05:53 PM
