ABS amigo reader
Old Oct 20, 2013 | 02:32 PM
ninjaff21's Avatar
Default ABS amigo reader
Just wondering if anyone has a reader that i can rent or buy. i checked the classifieds and did not see any. still its always worth a shot to ask.
Old Oct 21, 2013 | 10:00 AM
SoCal Rob's Avatar
It looks like Jafir is willing to help with this and is about 3 hours from you in NW Arkansas. Check out the first post in this thread.
-Rob
Old Oct 21, 2013 | 10:06 AM
mossmanxjt's Avatar
You can also look in to the Autel AL 619 scanner. You can get it on Amazon for around 200 bucks and it is a full functioning scanner that reads OBDII and ABS/SRS codes from pretty much any vehicle Land Rover included. I bought one when I had the three Amigo lights on. I was considering the ABS Amigo but I am glad I went with the Autel scanner.
Old Nov 14, 2013 | 08:58 AM
jafir's Avatar
The only current ABS code was for a bad PWM signal from the ECM.
021:Engine PWM Signal Bad
When we cleared the ABS code it didn't seem to return immediately, so I think that is a good sign.
You also had an ECM code of P1592 and also a couple of misfires codes and catalyst codes.
I figured I'd post the codes here in case someone has any ideas. My first thought, with those two codes together, is that the two computers are sometimes having trouble talking to each other.
You might want to get a replacement gauge cluster, so that you can more easily see if the amigos are on. You might check with Nigel's Car Place, I think he has used parts, or see if there are any u-pull-it type salvage yards nearby that might have one for cheap. There is a yeard near me that shows to have one for $10 at Car-Part.com--Used Auto Parts Market
Old Nov 14, 2013 | 09:36 PM
ninjaff21's Avatar
Thanks again for your help jafir!
tbesselman
Apr 23, 2012 07:54 AM
landRoverNewbie
Feb 27, 2011 11:29 AM
jkid
Jul 14, 2010 05:55 PM
Princess
Jul 4, 2009 12:24 PM
