ABS Amigo V1 USB in Denver CO
Old Feb 23, 2016 | 12:12 AM
nicksims's Avatar
7th Gear
Default ABS Amigo V1 USB in Denver CO
Anybody in Denver CO have an ABS Amigo that I could borrow or buy? If borrow, I'd be happy to show up bearing gifts.
2001 Disco SE2.
Recently cleared a stack of codes by replacing oxygen sensors, plugs and plug wires. No more engine light!
I still have the 3 Amigos and now need to fix those.
I've never asked to borrow a tool here so if that is just never done please tell me.
Thanks all. Reading your posts has been a lifesaver.
Thanks,
Nick
Old Feb 23, 2016 | 07:47 PM
chubbs878's Avatar
If anyone around Dallas has an ABS reader, I would like to borrow so that I can flush and refill and do the complete fluid bleed including the modulator
Old Feb 23, 2016 | 08:14 PM
Joemamma1954's Avatar
Nick, Any code reader that reads ABS codes, is all you need. Once you have them read, you can correct the problem. A common code is the shuttle valve, and the Option B fix will take care of that one, I did mine in a short time.
Old Feb 23, 2016 | 08:36 PM
jamieb's Avatar
2001 Disco SE2.
Thanks,
Nick
Option B costs about $10 in wiring and a couple hours time. I just pulled the trigger and went option B with no code scanner. Cleared mine up. Had it not worked, I would have gone farther to fix it.
sayeedA
Dec 5, 2011 06:39 PM
forestry17
May 6, 2011 10:10 AM
adwarren78
Aug 13, 2010 01:00 AM
jkid
Jul 14, 2010 05:55 PM
