ABS Bleed Necessary?
Old Dec 27, 2017 | 11:40 AM
nmacej's Avatar
Default ABS Bleed Necessary?
Hi everyone:
I know the answer to this is most definitely already posted somewhere, but I've looked and can't find just a straight-forward answer, and I'm going cross-eyed haha
I need to replace my Brake Master Cylinder, but like an idiot, I waited too long and got lazy, letting the fluid leak out of the seals/grommets. So here lies the issue, as I do not have a fancy Hawkeye scanner, etc... How do I get the air out of the ABS module? I assume since I pressed the brakes after letting the reservoir empty, that I can't just bleed the system at the BMC lines as I've read in a couple places, right? So, how do I get the air out of the ABS, and do I do that before or after I bleed at the wheels?
Thanks!
Old Dec 27, 2017 | 11:42 AM
Twix's Avatar
I did mine by having the truck running while doing the bleed. Then I took it for a drive and repeated the process about 3 times until I was happy with my pedal feel
Old Dec 27, 2017 | 11:46 AM
CollieRover's Avatar
Originally Posted by nmacej
Hi everyone:
Thanks!
There are instructions to make a switch you can us at the ABS relay to operate the pump. You’ll also need to bench bleed the master cylinder.You could always go get an obdII tool that bleeds brakes as well. There are a few now.
Old Dec 27, 2017 | 04:55 PM
nmacej's Avatar
I thought a bench bleed wasn't recommended with our BMC's because of the rear brake reservoir being a potential failure point, no? Most things I've read recommend bleeding the cylinder by backing off the lines going into the res. with pedal pumping. What are your thoughts?
Old Dec 28, 2017 | 07:46 AM
You could be right, but that is news to me. I did the bench bleed to mine, and not sure how it would be different from any other BMC.
schwaggy
Jul 14, 2017 09:34 AM
LR03NJ
Mar 10, 2016 12:35 AM
JavaDiscoII
May 29, 2010 04:33 PM
Chrisinhouston
Dec 19, 2007 10:20 PM
Ghoti
Mar 31, 2007 11:23 PM
