ABS Code won't clear
I bought an Autocom and hooked it all up thanks to SuperSport and scanned all of the systems for faults. It came up with a lot of codes in the ABS system so I cleared all of them except for a unknown code 115. The Autocom won't clear this code for some reason. Does anyone know what this code is or why the Autocom won't clear it? It is keeping my 3 amigos lit.
After driving around a while I hooked the AutoCom back up to check for codes and the ABS system had 5 codes
Unknown Fault 115
Unknown Fault 48
Unknown Fault 137
Unknown Fault 138
I tried clearing all of them but once again they all cleared except for the 115 so the three amigos are staying on.
Unknown Fault 115
Unknown Fault 48
Unknown Fault 137
Unknown Fault 138
Maybe contact autocom and see if they have an update? That doesn't look like a valid code number. Perhaps it's something simple like a programming error, and it's really support to be a 114?
I have seen that there is an update to the Autocom software. I could not figure out how to install it but has anybody installed it and successfully figured out what the ABS code 115 means?
er1c
Dec 16, 2013 11:10 PM
DiscoBenjamin
Oct 14, 2011 05:53 PM
