ABS ECU CHANGE OUT
RE: ABS ECU CHANGE OUT
NO! The ECU is NOT what is causing that. They are called the three amigos, try doing a search on them at the bottom of the site. The ECU is extremly expensive and there is no need to change it. Mike will add more to this, but I will be the first to say dont mess with that ECU.
im goint to assume you got it checked out, and that you do need a ecu, ie, configuration is getting lost, anyway, yes, it needs to be coded to the car, let it know if you have sls or diff lock, even if ecu is the fix for the lights, theyll stay on after you replace it until its flashed
Paul Grant
08-10-2014 12:29 PM
collin Barrows
08-28-2011 07:13 AM
