ABS Faults
ABS Faults
From ABS Amigo, sporadic Three Amigos, makes me think it is an electrical connection, as opposed to a faulty item. I have done the Option B. I wonder where i could have a bad connection? Any thoughts?
Interestingly, if i leave the ABS amigo plugged in, i never get the Three Amigos. Maybe that is my fix?
1.--Current Faults---->
Active Faults:
None
Logged Faults:
033:Front Left out valve open circuit
034:Rear Right in valve open circuit
035:Rear Right out valve open circuit
073:Front Left out valve short to supply
074:Rear Right in valve short to supply
075:Rear Right out valve short to supply
<-END Faults
Active Faults:
None
Logged Faults:
<-END Faults
jastutte (09-04-2020)
1st step you should try..
With any sporadic fault, ABS or otherwise, I would recommend applying Permatex Dielectric grease at the connectors as your first approach. I've solved the intermittent 3 Amigos and a few other fault codes simply by throughly cleaning the connections and using a small amount of Permatex DG. In fact, you should do this to all those connections, especially your emissions sensors near the charcoal canister as these can be especially vulnerable to dirt & debris.
i had the Option B fix fail on my '04 due to a bad ground in the same spot as your photo. the screw hole had become wallowed out and the bolt could not keep a good connection for grounding.
i moved the ground wire to the factory ground point on the fire wall behind bank one. i have had no issues since.
I cleaned, moved the ground. The captive nut was very solid. I will get the permatex for the connectors, is that different from dielectric grease? which I have.
It sounds like the abs sensors on the wheels?
Looks like mostly the right rear is the issue, as opposed last time, it was all corners.
The current faults are:
Active Faults:
None
Logged Faults:
Active Faults:
None
Logged Faults:
