ABS AMIGO Results
Old Feb 26, 2013 | 08:50 PM
microbc's Avatar
Default ABS AMIGO Results
I have been having intermittent 3 amigos and was able to plug in an ABS AMIGO today when the lights came on.
This is what was logged:
1.--Current Faults---->
Active Faults:
None
Logged Faults:
None
<-END Faults
..--Previous Faults--->
Active Faults:
None
Logged Faults:
114:Shuttle Valve Electric Failure
<-END Faults
Active Faults:
022:ECU Gnd or Reference Gnd bad
Logged Faults:
None
<-END Faults
Will the fix posted in the hall of wisdom to rewire the valve help in this situation?
Any thoughts on what I need to fix/replace would be appreciated
Old Feb 26, 2013 | 09:28 PM
dr. mordo's Avatar
The shuttle valve code requires either the rewire from the hall of wisdom or a new switch (or possibly a short somewhere).
I don't know about the ecu ground code. When my shuttle vqlve switch failed, I just got the shuttle valve code.
If I were you, I'd fix the shuttle valve issue, then see what happens. It may very well fix the other code too.
Old Feb 28, 2013 | 02:47 PM
microbc's Avatar
Does anyone know if there is a PDF version the
"ABS MODULATOR ELECTRICAL FAULT REPAIR" process listed in the sticky section at the top of the forum?
I would like to be able to print out the section I need, to have in the garage while I do the repair.
Thanks
jamestfl
Jun 25, 2015 03:19 PM
seaosrover
Oct 23, 2010 01:48 AM
bosshogt
Sep 18, 2010 01:16 PM
Princess
Jul 4, 2009 12:24 PM
