ABS, Hill Desent, low pedal?
Old Sep 24, 2012 | 06:13 PM
dandbculp's Avatar
3rd Gear
Default ABS, Hill Desent, low pedal?
01 disc II SE7 Problem: ABS, Hill desent, and Traction Control light come on when brakes are applied, and low / no pedal when brakes applied with medium to hard pressure. History: Calipers, rotors, and pads replace 2 years ago with less than 12k miles put on since. Problem has just started. Local shops can't find problem, and I have check the system over. Even sprayed vaccum lines looking for a leak. Seems like booster is bad but no rust or damage seen. I have heard the problem could be air in the lines, abs module, or booster. I do not have money to burn by just throwing parts at it, so any help or guidance would be great. Thank you for your help.
Old Sep 24, 2012 | 06:42 PM
ZGPhoto's Avatar
You put 12k on in two years? Damn... I wish it was that low for me
Old Sep 24, 2012 | 06:57 PM
lr2001silver's Avatar
Banned
I might put on 5k on my truck per year and that's if i take my road trips out west.
Old Sep 24, 2012 | 08:31 PM
I guess I'm out of the norm, I try and put as many miles on as I can.
Old Sep 24, 2012 | 08:35 PM
Banned
Funny Phil, you also like turning wrenches lol keep them wheels turning.
Old Sep 24, 2012 | 09:38 PM
I HATE turning wrenches, I have better things to do.
Plus I have no patience anymore.
I do it out of necessity.
Old Sep 25, 2012 | 06:15 AM
drowssap's Avatar
have you had the ABS codes check and what were they?
Old Sep 25, 2012 | 08:53 AM
dandbculp's Avatar
3rd Gear
Its not my daily driver any more, my wife uses it for work, which is 20 miles round trip.
Old Sep 25, 2012 | 08:54 AM
dandbculp's Avatar
3rd Gear
As for any codes, the ABS is not showing any, Which is why I dont think its the module.
Old Sep 25, 2012 | 08:57 AM
First thing you need to do would be a full 2 quart DOT 4 brake flush after first checking your current level and check all the lines for leaks.
As for the ABS, you need to find a shop that has a scanner able to read ABS codes on your truck, few can, and they can only be read when they are on.
If you can not find a shop with a scanner, buy a 3 Amigos scanner for $200 from RSWsoultions.com and do it yourself.
If you want some help, lets talk.
fmbchoppers
Jan 23, 2015 08:58 AM
starcraft1
Sep 14, 2011 10:03 AM
Susan FG
Jul 7, 2011 10:31 PM
sean2k
Jan 27, 2010 12:32 AM
NWDiscoRover2004
Oct 15, 2007 11:49 AM
