ABS light is on
Old Nov 23, 2007 | 10:32 PM
discoboyd's Avatar
Default ABS light is on
W have had the brakes worked on twice in the last six weeks. Now have new pads and leak has been repaired.
But the ABS light came on a couple of days ago. Is this something that requires attention from a dealer or is there something I can do to address this?
Old Nov 24, 2007 | 09:10 AM
Default RE: ABS light is on
There is nothing you can do about it, if you want to give me a call I can walk you thru a couple of self tests that you should do prior to seeing a mechanic.
303-862-7680
Colorado between 7 am and 8 pm
Old Nov 24, 2007 | 09:11 AM
okdiscoguy's Avatar
Dealer or indy shop with a scanner that can read rovers. Probably a dirty/loose sensor. If your brakes are dusty or squeal, it will throw a code and you might not have ABS. Search brakes on here for some good brand recommendations. If you just use the Autozone pads, you are going to regret it.
marlymarl
May 28, 2011 10:34 PM
Brad S1
Oct 26, 2006 08:53 PM
Surfin Elvis
Jun 23, 2005 11:08 PM
