ABS Light
Old May 14, 2022 | 09:34 PM
eitydeuce's Avatar
Default ABS Light
Hello there, it’s been a while since I’ve been on here but I’ve just been enjoying the Disco 2 too much lol. So I finally got around to doing the three amigos sticky and got everything put in and 2 of the 3 lights went out. I still had the ABS light on and when I went to scan it my scanner said it was unable to communicate with the ABS module. I double checked the wiring according to the pdf in the thread and made sure the connectors are correct. Could this be a unrelated issue or is there anything else I can try, it’s kind of difficult to pin point it since I can’t see the abs module on my scanner.
Old May 15, 2022 | 09:52 AM
disco96sd's Avatar
you don't have the necessary software on your scanner - you might try the autozone scanner to get the code - they use a scanner that captures pretty much any code and then they go to their computer that goes to the autozone's central database that has all the software - the scanner won't reset it but you will get the code to know what you are dealing with - it is free to borrow the scanner in the parking lot and get the code
Old May 15, 2022 | 01:23 PM
mln01's Avatar
First, as you may have already learned, the ABS light does not go out until the truck is driven a little way and to a specified speed (I don't recall the spec). That's for the SLABS to confirm it is "seeing" a signal from all four sensors.
As for your scanner, was it reading the ABS codes previously? Can it read engine management codes? If the scanner worked before but it's not working now it's possible, but rare, that the power feed to the OBD II port in your truck has gone kaput. This happened with a friends truck here and we got it working again. Please let us know.
Old May 15, 2022 | 01:38 PM
disco96sd's Avatar
True ABS light does not go out until you drive about 5mph
Old May 16, 2022 | 05:52 PM
eitydeuce's Avatar
Yup, as soon as I test drove it the light went away. Thanks for the info, I’m now 3 amigos free!
Old May 18, 2022 | 04:11 PM
jastutte's Avatar
that's a great feeling, isn't it?
just did the same on my '01. felt great.
up until the rear, rusted out brake line decided to start pissing all over the place. that didn't feel so great.
chockster
Feb 20, 2017 03:41 AM
wyrdvans
Jul 15, 2013 06:10 AM
SSL9000J
Nov 18, 2012 08:42 PM
Lee97Disco1
Dec 8, 2010 07:14 PM
AzCamel
Mar 3, 2006 06:03 PM
