abs light on
Old Aug 13, 2007 | 08:59 AM
discoken's Avatar
Default abs light on
Hi I just changed the pads & rotors on my 99 Discovery 1 and now the abs light is on from time to time. The brakes also pulsate from time to time when I brake. I used regular generic pads & rotors. I've read that cleaning the sensor can help clear this? If so, where is the abs sensor? Any advice on how to troubleshoot this? Thanks.
Old Aug 13, 2007 | 09:46 AM
Default RE: abs light on
What pads and rotors did you use? There shouldn't be any brake pulsation with new rotors unless they were stacked on there side too high and too long and they will have problems. Do you get a ny brak dust, brake squeaks while stopping?
Old Aug 13, 2007 | 10:52 AM
discoken's Avatar
I did notice a bit more break dust than before. No squeaks while stopping. This started after changing out the front drivers side pads & rotors.
Old Aug 13, 2007 | 12:07 PM
98roverguy's Avatar
Although I have not yet done a brake job, I know that the sensors can trip if they are not secure in the seated position. Sometimes after a brake job they can become slight loose or not seated propoery which will trip the sensor due to moving things around.
Old Aug 14, 2007 | 10:59 AM
discoken's Avatar
One other thing is that the abs light comes on probably half of the time. Which wheel has the sensor on it?
Old Aug 14, 2007 | 11:18 AM
98roverguy's Avatar
There should be a sensor on each wheel, specifically where I'm not sure as I have not dived into this. My sensor comes on from time to time as well. A while back I took it to Land Rover and they said my left front sensor was just falling apart and that "they just do that". They gave me a ridiculous quote as it's something I can do myself, just was never too concerned over it. Your getting occasional brake pedal vibrations because one of your sensors is not recognizing the wheel and sending a signal to deploy abs. I recommend that you unfortunately take your tires off one by one and make sure your sensors are seated properly. They trip easily if they are not in that sweet spot.
Old Aug 14, 2007 | 11:19 AM
All 4 have sensors. What you need to find is which brake is pulsating, possibly a loose bearing or a bad hub will cause this.
Old Aug 14, 2007 | 04:49 PM
Bigmonty's Avatar
do Disco hubs go on a normal basis ? and is there a easy test to check if ya have a bad one
Old Aug 14, 2007 | 06:18 PM
What year and how many miles on your truck?
Old Aug 14, 2007 | 08:36 PM
Bigmonty's Avatar
00 disco II 145000 I have never had one changed, i dont get any "unnormal" sounds this is why i asked if there is a way the check it
