ABS light
Old Sep 14, 2007 | 02:07 PM
rlp2011's Avatar
8th Gear
Default ABS light
I recently clean and adjust all my abs sensors because I have the right front not in the right position my question is I'm sure that the sensor is not bad becuase since I clean it is not doing the soft pedal and activating the abs how I can get rid of the anti lock light?
My other question is how do I perform a engine flush?
Thanks!
Freddy
99 Disco Sd 134k
Old Sep 14, 2007 | 02:26 PM
okdiscoguy's Avatar
Default RE: ABS light
Have to have the codes read and cleared by the dealer or a shop with a comparable scanner like autologic.
For the flush. Drain oil, fill back with ATF. Idle for 20 minutes DO NOT DRIVE. drain, change filter and fill with your favorite oil. Be sure to use a quality filter so it doesn't drain back. K&N and Mobile 1 filters are favorites on here..
Old Sep 14, 2007 | 03:13 PM
rlp2011's Avatar
8th Gear
Mmmmmm ok so autozone or places like that it won't work? For the flush can you tell me how much of ATF? And stupid question what's is ATF? And what type of oil 20w 50w ??? And how many qt.? I live in Florida very hot here
tks for the help
Old Sep 14, 2007 | 06:47 PM
okdiscoguy's Avatar
Nope, Autozone can read anything with your check engine light on related to OBD2 faults. Not ABS Faults.
ATF= Automatic transmission fluid. You need to get an owner's manual to see how many quarts your truck takes, and what type of oil. Probably 10W40.LR changed motors and body styles in 99. Depends on if you have a D1 or a D2, Bosch or Gems. Just drain out the oil and replace what comes out with the same amount of ATF. Some change the filter before, some don't
Might want to have a shop do your flush. Doesn't sound like you are the handiest person. No offense, but if you have a lot of buildup, you have better be ready to drop the pan and clean out the oil pickup tube.
Why are you wanting to do a flush?
If you need an owners manual and workshop manual, rover-renovations.com will send you one for free. YOu can also download one off the web. Just Googlle free manual download for discovery or something. Not sure where it is.
Old Sep 17, 2007 | 06:06 PM
rlp2011's Avatar
8th Gear
lol Tks. for the handi....is my first truck,andI always worked on my cars is just I never heard the term ATF. my land rover mechanic told meabout my flush wen he change the valve gasket
Tks.
Old Sep 17, 2007 | 06:07 PM
rlp2011's Avatar
8th Gear
I got the manuals and I Have a Disco Sd 1 134k
marlymarl
May 28, 2011 10:34 PM
Brad S1
Oct 26, 2006 08:53 PM
Surfin Elvis
Jun 23, 2005 11:08 PM
