ABS Light HDC failure Light and TC light have come on, WHY???
Old Nov 3, 2006 | 10:03 PM
Elhoff's Avatar
Default RE: ABS Light HDC failure Light and TC light have come on, WHY???
I just went through this on my 99 Disco 2. I was running drilled/slotted rotors, and carbon fiber pads. I had lots of rear pad left, but was down to about 3mm on the fronts (still in spec). Changed the pads to factory pads all around, and had the dealer clear the errors (front right ABS sensor had variable output). One week and 300 miles later, all is still well. Dealer commented that they see more of these errors with the slotted/drilled rotors (but no attempt to get me to change).
Elliot
Old Nov 4, 2006 | 01:27 PM
ryanrover's Avatar
So I have the same thing as well. I can hear a ringing noise coming from the ABS housing area, even when the vehicle is shut off. I also have to pump the brakes to get a solid braking effect to take place. I have not had the rotors/pads looked at yet. Any ideas on the ringing part?
Thanks,
Ryan
Old Mar 6, 2007 | 07:49 AM
Craig SA's Avatar
4th Gear
Hi Mike,
I live in South africa in the middle of the Kalahari - far from dealers etc that can help. I seem to have the same problem as mentioned in this thread.
My brakes squeak and quite clearly need to be replaced. Today, all 3 lights came on, so I assume that it is time to tackle the job.
Can you assist me in going through the replacement step by step. I hope to have the parts here by the end of the week. Am I correct in saying that at this stage all I need to order is the brake discs and a set of pads?
Craig
Old May 27, 2011 | 03:22 PM
cadleji's Avatar
I have an 03 Discovery and my 3 amigos as well as my service engine light came on today. i unhooked the battery cables and cleaned them throroughly and all but the ABS went off. Thanks for the advice!
Old May 27, 2011 | 03:43 PM
DarylJ's Avatar
Originally Posted by Craig SA
Hi Mike,
Craig
Page 70-38 for the procedure in this manual. Give it a read and ask questions if you have any.
Old May 28, 2011 | 07:46 PM
tshah209's Avatar
I'm confused about the page number.
Old May 28, 2011 | 10:34 PM
DarylJ's Avatar
It's section 70, page 38. You'll see it on the bottom of the pages, they are all marked that way.
Aulmeck
Feb 4, 2022 05:18 PM
Wayne
Oct 2, 2020 12:10 PM
Alan Phillips
Nov 19, 2018 03:27 PM
cipher982
Dec 13, 2011 07:50 PM
Cosmic88
Mar 9, 2011 06:53 AM
