ABS light/ TC light/ Descent
Old Oct 14, 2015 | 03:47 PM
AFDisco ll's Avatar
Default ABS light/ TC light/ Descent
having an issue periodically with all three warning lights coming on at the same time. I just had new brakes/ rotors and all the good stuff. But every so often those 3 warning lights come on. In sure that the must be on same circuit or relay. Any ideas guys?
Old Oct 14, 2015 | 03:50 PM
Joemamma1954's Avatar
They are the infamous "3 Amigos". You will need a code reader that reads ABS and get the codes. Once this is done post your codes and we can help with getting off. Chances are it is the shuttle valve, and there is a mod on the sticky, I did mine and they have never returned.
Old Oct 14, 2015 | 03:52 PM
By the way, they are all connected, and one will disable the other functions. So it is best to fix.
Old Oct 14, 2015 | 04:55 PM
chubbs878's Avatar
This is one of those issues that's best to run searches on. There are hundreds of posts about this spanning several websites but it's even been thoroughly exhausted here, alone
Old Oct 15, 2015 | 06:55 AM
drowssap's Avatar
you need to get your ABS code read there are 16 different things that can trip the Amigo's.
MGWAL001
Jun 5, 2012 12:25 PM
gamecockdisco
Jul 12, 2010 08:34 AM
blackrover
Aug 20, 2007 06:40 PM
Sean 1313
Aug 30, 2005 10:00 PM
ecustreetstang
Feb 10, 2005 06:34 PM
