ABS Live Data - WSS
Old 04-04-2018 | 08:53 AM
coors's Avatar
Default ABS Live Data - WSS
I have a Foxwell scanner capable of reading ABS module data. I’m attempting to track down the cause of an intermittent (Four Amigos) left rear sensor low output error. Sensor and hub are new.
I could drive for days without the light illuminating. Or minutes down the road it just takes a simple bump in the road for the light to come on. Another Amigo trigger, applying the breaks while riding over bumps in the road.
My question is, I am trying to monitor live wheel speed sensor data, but the ABS module drops communication after ~30 mph. Trying to understand if it’s just my scanner disrupting the communication to the ABS module or a simply a function of the ABS module.
I have successful monitored wheel speed sensor data in other vehicles (over 30mph) without disruption in signal communication.
Anyone have any experience w/ Rover ABS modules that have successfully monitored wheel speed sensor data over 30 mph? I have to image so...
Old 04-04-2018 | 10:12 AM
Twix's Avatar
No idea about monitoring, but it sounds like you need to replace the left rear sensor, or try to reseat it.
Old 04-04-2018 | 02:01 PM
coors's Avatar
I agree. That’s what I’m leaning towards, reseating the sensor.
I’ve seen where even a marginal layer of rust/pitting on the mounting surface can throw off the signal. I’ll pull the sensor, sand down the surface, reseat ensuring the sensor is seated flush with the mounting surface.
Old 04-04-2018 | 02:22 PM
JUKE179r's Avatar
Swap left for right, right for left sensors to see if it is really bad.
Old 04-04-2018 | 06:53 PM
coors's Avatar
come on...now that’s too easy 😜
Old 04-04-2018 | 07:06 PM
CollieRover's Avatar
Consider finding a Hub on eBay. I did my front hubs, and paid I think 130 or so for both. Then you can keep the stock plug at the wiring harness. I had better luck with the sensors that came with the hubs than with the replacements you solder in.
04RoverSe
02-23-2018 09:35 PM
kfx4001442
08-29-2017 02:17 PM
jmason
Off Topic
11-14-2011 03:33 AM
JumPeR04
08-19-2011 09:56 PM
Robover01
11-24-2009 11:09 AM
Quick Reply: ABS Live Data - WSS
