ABS MODULATOR FIX (NO more SVS fault)
Old Aug 1, 2011 | 05:39 PM
  #61
ralphobell's Avatar
Default Flat Trailer Connector - Napa
The Napa part number for the trailer connector is 784640. I paid $2.79 and will be installing this weekend.
Old Aug 13, 2011 | 09:01 PM
  #62
ralphobell's Avatar
Well did not need to do the bypass at this time. Pulled the modulator and tested it and one of the shuttle valve switches were bad. Replaced the shuttle valves and the seals. I'm now Amigo Free! Thanks for the write up Josh! It truly made this job easy.
Old Aug 17, 2011 | 05:26 PM
  #63
jjadams's Avatar
I am a newbie here on this site and looking to do the abs fix tomorrow but for some reason I am not able to print this off. Hopefully i am asking for help in the right place and was wondering if someone could email it to me or what my options were as far as getting this printed off. Thanks for any help
Old Aug 21, 2011 | 12:39 PM
  #64
caljw's Avatar
Originally Posted by caljw
Add me to the list of hopeful success stories. One week now after option B and no Three Amigos!!!! Getting the 3 allen screws out was the only pain. Use a 2x4 to lift and allow room to work and a very short allen key is your best bet to keep it turning without having to find the screw each small rotation. The job took me a few hours but that was taking it very slow (I am not a wrench by any means) slow and steady with a couple of cold ones and the laptop nearby.
Josh, many thanks to you for the excellent write-up. Saved me about $1100 for the shuttle valve rebuild. My independent LR shop is amazed. Of course they don't want the word to get out!
Ruh Roh.....after 4 months Amigos return. Ground is secure. Guess I'll have to dive into the modulator again. Bummer.
Old Oct 10, 2011 | 08:47 PM
  #65
riddings's Avatar
I just purchased a used Land Rover Disco 2 with the 3 Amigo's lit up... Completed this repair along with bleeding the brakes in just under 4 hours... It's been a couple weeks now and haven't seen the 3 amigo's since...
The only hazard while doing this repair was while soldering the wires, I put down the soldering gun, and without looking went to pick it back up... Yeah, I grabbed the wrong end. The good news. The solder gun was hot and ready to go... The bad new. The solder gun was hot and ready to go...
Besides my little error with the solder gun - the fix went smoothly! Thanks for the awesome write up!
Old Nov 18, 2011 | 09:57 PM
  #66
michaelfisk's Avatar
I did this and it worked great for about a year. Now I have no ABS response for anything. No TC, ABS, or HDC. No lights, or chimes either. Any ideas?
Old Dec 18, 2011 | 01:05 AM
  #67
Rdhilaire's Avatar
Hey, Am I in??
Old Jan 13, 2012 | 05:53 PM
  #68
Mr. Clean's Avatar
Default Did mine... No more Three Amigos
Gotta say, this is a great piece of info. Great thread!
I did the fix this past weekend and had no problems at all. I skipped straight to the bottom section and went from there.
My SV was bad, replaced with a new one from BP, and new that that was the extent of my issues, but went ahead and did the fix anyway, just because I don't ever want to see those "GUYS" again!
Old Feb 10, 2012 | 01:48 AM
  #69
mx468's Avatar
I've been getting the three amigos on and off lately and now it's more on gonna try this fix soon. Option B.
Old Feb 16, 2012 | 02:21 PM
  #70
mx468's Avatar
Ok I tried to fix my abs doing the B option yesterday and as I was unscrewing my first hex bolt, it sheared right off, so now I need to remove the whole modulator, so be careful when unscrewing those damn hex bolts...
