ABS Question
I recently had the ABS Module repaired on my 2002 Discovery 2. After doing that I hadn't been able to clear the Three Amigos and twice while driving in rain the truck wheels/brakes locked up while coming to a stop on the slick roads. I have just had the Three Amigos cleared and have been driving it around for the past couple of days and the Amigos have not returned. Should I be concerned about the wheels/brakes locking up? Or just keep driving it until any codes come up...
Three Amigos lit up. I had the shuttle valves and seals replaced on the brake module. The person who helped replace the parts did not have an ABS scanner so I left it as is (Amigos still on) after repairs for several months which is when the brakes did what I had mentioned. I then had another friend with an ABS scanner scan, then erase the Amigos. They still have not come back, but was concerned with the brake issue. I hope that clarifies. Thanks!
So, the next time the check engine light comes on with a 1590 fault code number, it will be time to use the 3 amigo scanner again and then get back to us with the exact fault code number.
OK, I had the engine scanned again and these are the codes that activated...
P0306, 88-Brake Light Relay-Open Circuit, 116-Internal Supply, 134-Shuttle Valve Switch. I know that the 0306 is related to the #6 plug. They were changed within the past year. How would I test the plug ( I do not have a timing light)? Any suggestions for the ABS stuff is appreciated. The three amigos is still not on. Thanks!
Alright the problem was as simple as replacing the #6 spark plug. Thanks for the advice. Todays project is to dig deeper into the ABS issue. I am gonna run through Atlantic British' test procedure for shuttle valve switches. The downhill descent light has activated a couple of times since my last post.
