ABS Question
Old Aug 15, 2015 | 10:32 AM
Boats12's Avatar
Forgot to ask what should I be looking for to inspect regarding the 116 code that mentioned something about Internal supply?
Old Aug 15, 2015 | 10:53 AM
Charlie_V's Avatar
Originally Posted by Boats12
Alright the problem was as simple as replacing the #6 spark plug. Thanks for the advice. Todays project is to dig deeper into the ABS issue. I am gonna run through Atlantic British' test procedure for shuttle valve switches. The downhill descent light has activated a couple of times since my last post.
Do you have a link for the test procedure?
Old Aug 15, 2015 | 12:21 PM
Boats12's Avatar
Land Rover Troubleshooting - Test Procedure And Instructions for Shuttle Valve Switches
Old Aug 15, 2015 | 01:32 PM
Boats12's Avatar
On the last continuity check between the C0504 pin 12 and the C0362 ground connection I found that the ground connection nut was barely was barely on probably close to the last thread of the bolt. When I checked continuity it was not consistent. I tightened the bolt back down and the continuity checks ok. My big question now is..Could this be the problem relating to all of the codes that I mentioned including the brakes locking up on slick roads?
colemtd
Mar 30, 2019 08:57 PM
dammad
Jan 26, 2009 01:50 PM
cottonpatchweims
Feb 10, 2005 07:18 PM
cottonpatchweims
Jan 14, 2005 01:59 AM
