ABS Repair kit
Old Sep 27, 2008 | 12:43 AM
Willie 00D2's Avatar
Default ABS Repair kit
Has anyone tried this Shuttle Valve Repair kit? I have the three amigos on.
http://www.jewellamberoil.com/sales/...roducts_id=190
Willie
Old Sep 27, 2008 | 01:59 AM
Disco2Guy's Avatar
Default RE: ABS Repair kit
Never heard of them or their "special" kit. Have you had your codes read?
Old Sep 27, 2008 | 07:45 AM
I have heard of the repair kit, do not know how well it works.
You had the codes read, what did they say?
Old Sep 27, 2008 | 08:34 AM
If you do a panic stop at 30 MPH plus, can you feel the ABS pulsate thru the brake pedal?
Have you actually had a mechanic read the ABS codes, if not, you are putting the cart in front of the horse.
Old Sep 29, 2008 | 09:59 PM
tacomatech's Avatar
I have done many svs modulator repair kits. It involves replacing the shuttle valve switches and the solenoid pack. In doing so, you are replacing all electrical components in the modulator. Make sure you actually have the necessary svs fault codes first, and then
carry out the electrical checks as well. I have not ran into one yet that actually has a wiring fault, but thats not to say that there is not a wiring problem with yours. All of the SVS kits that I have done I have never seen back. It is a reliable fix and is far cheaper than replacing the entire modulator. CHECK YOUR FAULTS FIRST THOUGH!
-Kyle
aarongregor
Dec 1, 2015 08:43 AM
sorusty
Feb 26, 2014 12:26 AM
aarongregor
Jan 16, 2012 07:02 PM
majrmike
Oct 9, 2007 03:13 PM
