abs sensor extensions
Old Mar 24, 2014 | 10:16 AM
dusty1's Avatar
Default abs sensor extensions
where to get em? is there any way, not obvious, to get more slack? maybe homemade extension, possible?
EE slickrock, the way to go? l8 maybe have em? I don't see them there.
off road yesterday and after a few drops and one big bump, 3 amigos on.
amigo said fail electric signal lr/rr/lf.....
I looked and all were yanked loose, so I must remedy. thanks
Old Mar 24, 2014 | 12:46 PM
ZGPhoto's Avatar
Just EE if I recall correctly.
But in reality, it's just 2 wires. You could always just cut it and splice in 2 wires.
Old Mar 24, 2014 | 12:54 PM
dusty1's Avatar
answer I was looking for I have a box of hubs w/sensors. I couldn't figure out any harm in using those wires, to patch in. I figured, I just need to seal up the splice and am good to go.....thank you.
so unless I hear of any catastrophic ill effect, that is the plan. I'm one 4" piece of duct tape away, from having the most ghetto disco in north America.
Old Mar 24, 2014 | 12:56 PM
dusty1's Avatar
just butt splices should work, right?
I guess the front lines put on the back would solve 1/2 the problem. then just splice the front
Old Mar 24, 2014 | 01:07 PM
ZGPhoto's Avatar
Correct sir.
The $140 ABS sensor line that you can buy from Land Rover literally makes you splice into the existing wire...
Old Mar 24, 2014 | 01:13 PM
dusty1's Avatar
well, I should conclude this thread by stating "the absolute best deal on these extensions is not from EE, but the hefty tub in the corner of my shop. free shipping and fastest delivery ever. oh, and they are free"
Old Mar 24, 2014 | 01:25 PM
ralphobell's Avatar
Just make sure you get solid connections. It measures the resistance if I remember correctly...so to many connections could effect that. I would Solder the splice and heat shrink for the best results.
Old Mar 24, 2014 | 10:54 PM
Dane!'s Avatar
When I do electrical I solder each connection, then heat shrink each wire, then heat shrink them all together with one larger one that has a glue inside it. They are insulated and water/heat resistant.
Old Mar 24, 2014 | 11:04 PM
dusty1's Avatar
well, i appreciate the direction, guys. But i just crimped them in some waterproof butt clamps, then stuffed some rtv in there.................we'll see if they hold. if not, i will pull out the iron and go to work.thanks, dusty
Old Mar 24, 2014 | 11:52 PM
ZGPhoto's Avatar
Any codes?
