abs sensor wire chafing front left
Old Feb 22, 2022 | 08:21 AM
newworld's Avatar
Default abs sensor wire chafing front left
2000 discovery 2 v8
3 amigos issues, traced to a bad abs sensor wire front left.
upon removal, found that the wire was worn thru about 3-4 inches from the sensor, rubbing against the hub assembly/caliper bracket area.
this is 2nd time i went in there all chafing was in same place, but not like i can reroute the wire, it goes through a squirrel hole in the hub right before the sensor hole.
i wrapped the wire in some wrap...just curious if anyone else has this issue?
Brandon318
Jan 12, 2022 07:54 PM
John Carlson
Sep 8, 2021 07:06 PM
JoeLena
May 20, 2018 01:17 AM
shady milkman
Mar 1, 2016 06:03 AM
trialrun
Dec 17, 2014 03:08 PM
