ABS Sensor wires
Old Oct 27, 2007 | 10:19 AM
shearer60's Avatar
6th Gear
Default ABS Sensor wires
First, thanks for the tip on the brake fluid tank switch. Saved me adjusting the emergency brake.
Now the three @#%$ lights are on. This time they have stayed on. I remember someone saying their connectors were corroded. I have them located. How in heck do you get them apart to clean them?
Last two times to dealer they found that it had switched to air suspension???? reset it and all ok for a month. On again could not find any report of them being on. (They went out on trip to Pitts.)for repair.
Been on for a week now. Have tried the battery cable disconnect. Did not work this time.
I will not go into what was replaced while it was there for that problem.
Thanks for being there fellers.
Con 2000 disco 2
Old Oct 27, 2007 | 11:21 AM
Default RE: ABS Sensor wires
Battery cable disconnect does not clear a hard ABS fault.
If you have the trio on, go get the codes read, keep all the code numbers and then clear the codes. 90% of the time, when cleared, they won't come back on and if the do then you may need to look at that particular part.
Are your wheels cover in brake dust, do your brakes squeak, either of these two will throw the bulk of the false/soft codes.
KlamathMatt
Apr 17, 2020 05:27 AM
Discodaisy
Sep 8, 2018 10:26 AM
crumleyjc
Jul 13, 2012 01:57 PM
twaszak
Jun 4, 2011 07:49 AM
